Links are now removed.
The way the update/patching is handled now can no longer be done by downloading a single file patch.
So now update/patching can only be performed via the "Check for Update" options.
Display unit for CMB849 controller in V8 Scantool dashboard are not showing...i.e., no psi, MPA, designation when setting dashboard display units.
Got any screen shots. It's working fine here. There was a report of units missing the version prior to the current version.
Have you downloaded and installed the latest version, I'm updating it fairly regularly.
https://www.efilive.com/index.php?op...=48&Itemid=133
Stand by...yes I just updated to Apr,23 from Apr,20
thanks for the update ,,
but i can't log the data with V8
I noticed on the latest release that when you add a new PID from the list on the right it collapses. I dont recall it doing this in prior releases but it might just be me.
Would it be possible for the list to stay where you are in the list after adding a PID so you can continue browsing PIDs where you were before you added a PID to be logged?
Yes, that is a bug and is being fixed.
FYI
It is controlled by the Property setting: Scan Tool -> Dashboard -> Expand PID Selection Groups Automatically.
Check that box to force the groups to always default to expanded.
Un-check that box to force the groups to always default to collapsed.
When selecting a PID, that setting is being incorrectly triggered and if it is unchecked then the PID groups will always collapse, if it is checked then the PID groups will become (or remain) expanded.
The next update will not trigger the expand or collapse on PID selection, i.e. the current collapse/expansion state will not change.
It also (incorrectly) happens when clearing the search criteria by clicking on the blue X.
That is caused by the installation not installing some config files correctly.
To force the V8 config files to be re-installed when the software is started, do this:
- Exit from all EFILive software.
- Edit the file: \My Documents\EFILive\Config\EFILiveScanAndTune.ini and delete the two lines that look like this:
[AutoUpdate]
UniqueID=224- Save the file
- Then re-run the V8 software.
