Set them both to 140 degC.
Bad, I stuffed up with the frame numbers as you cannot remove the data with a filter applied. If you look at frame 5800 (no filter applied) you will see the type of lean spike that needs to be removed.
No harm done. With a manual DFCO gets filtered out easily, but with an auto, if it is active you need to remove some of the bad data manually.
With posting a screenshot, I just hit ctrl+printScrn with the screen displayed. Open paint in windows/accessories. Then in the edit tab select paste. This file you then save as. You may need an editor to reduce the file size under1.00mb for efilive to allow you to upload it. I use Irfanview.
Here is that log with the dfco manually removed.
