V2 and PLX wideband?
Anybody successfully get a PLX wideband to show up using the serial port in efilive. I for the life of me cannot. I have the SM-AFR and it has a Tx port which is a 3.5mm stereo jack serial output. I have the cables i used for my innovate and that works great for my innovate, only difference for the PLX is i have to use a 2.5mm to 3.5mm adapter. Any ideas i cannot get this thing to show up
Could Tx and Rx be accidentally swapped?
Dont think so cause my wideband innovate works fine. The only difference between innovate and plx is i need to use a 2.5mm to 3.5mm adapter on the plx. I will play and see if i can get analog to show up, somewhere i read analog updates faster than efilive anyways so serial no better. Not sure how true that is though
The PLX requires adding in a ttl to rs232 serial port to work.
https://forum.efilive.com/showthread...-SM-AFR-Serial
PLX SM AFR TX & RX Ports are for daisy chaining to other PLX Devices.
