Hi I want to know if this scanner will work with an renault 21 txe 1991 with osb1 and a renix multipoint inyection ? I don't know if any of the cars uses that kind of inyection.
Thanks.REgards.
Thanks.REgards.
The EFILive V4 scanner software only works with GM's ALDL protocol.
Other manufacturer's such as Daewoo and Lotus also use that same system on some of their vehicles.
However, I do not know if Renault uses GM's system, that is something you would have to ask someone who knows how the Renault systems work.
