csp5. 06 dodge Cummins thanks.
Sorry but changes to CSP at this stage won't happen, it is a major deal to modify them.
Will v7 get read write support for E92?
I don't get that Chris, some read time comparisons:
Type
V7.5
V8
T42 2:22 0:34 E38 3:54 1:45 T43 4:24 1:36
Cal and full flash times between the two are also significantly different (V8 is much faster and more stable).
Aside from that, the E92 (and others) use a different addressing format not easily handled by the V7.5 software.
I noticed with this update when checking for DTC in BBL on an LML.
I have a DTC showing on a LML ECM.
When I go to F3, Diagnostic, F1, Display DTCs and
F1, EPA Current: No DTC Detected
F2, EPA Pending: No DTC Detected
F3, MFG Set: P2598
P2201
P003A These 3 codes show.
In the past these type of DTC were seen when selecting F1.
Did something change or is this a problem?
Any update for BBL when the LML BBL PID for DPF Soot will be working?
^^^^This has been for a while now.
I get you... i just like the simplicity of one software to do it all... My guess is that I like 7.5 so much I don't want to change???? LOL... Wish we could edit on v8 so I could make the jump....
