June 2020, Beta Release - Release 2
ATTENTION - BETA SOFTWARE RELEASE
We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Fix Summary:
Changes to V8 software
- Fixed CMC reading checksum issue.
- E45 (LB7) and E60 (LLY) serial numbers are now shown in the [F4: OBD] window.
- Additional USB message management to mitigate the $0101 error that may occur on some USB configurations.
- Tune files from A40 controllers that identify as "A46" can now be opened the V8 software.
Changes to V2 firmware (V2.07.162)
- Fixed slow black box flashing.
Changes to V3 firmware (V3.00.042)
- E45 (LB7) and E60 (LLY) serial numbers are now shown on the V3 screen when selecting: Diagnostics -> F1: Display Info -> F1: Display VIN/Info
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.30 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.042 (Jun 20, 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.162 (Jun 19, 2020).
Download here:
Known Issues: Issue #1:
None
Workaround:
N/A
Regards,
The EFILive Team
