Logworks and {B3601}
{B3601} is 14.628573 AFR (stock)
Logworks gasoline setting is 14.7
EFILive will not save @ 14.7 and
Logworks will not save @ 14.628573
precision is .1 either 14.6 or 14.7
My question is does it matter if these match perfectly or not?
I believe that because these settings are not programmed to the LC-1
it does not matter, especially when using serial connection.
I have always had Logworks set to gas (14.7) but diesel (14.6) is closer to
the value {B3601} will save. :confused:
My idea is to use serial Lambda and create an appropriate ben calc pid for it (something like GM.EQIVRATIO * EXT.WO2LAM1... did I get that right...?)... I haven't tried this yet, my LC-1 is off my car at the moment.
Depending on where you look Stoich for gasoline is 14.6 or 14.7
but it does not matter with serial connection because the fuel settings
do not change how the LC-1 interpolates data from the sensor,
just how it's displayed through Logworks.
1 EQ does not have to be equal to 1 Lambda. (whatever it is)
BTW I made a PID for External Wideband EQ
"({B3601}/{EXT.WO2AFR1})"
Commanded EQ is "({B3601}/{GM.AFR})"
