1 Attachment(s)
6.2L E38 no run no noid light pulse
I am new to EFILive and tuning. I am muddling my way thru the parameters.
I cannot get the 2010 Camaro 6.2 6spd manual E38 standalone harness to run. I have 2 DTC's, P0107 and P0621.
MAP sensor has 5v and don't think the P0621 gen light would keep it from running. I had someone build the harness and disable VATS.
I have been searching the EFILive site for hours for vats settings and have found nothing that helps explain G1208 and G1211.
The B9903 disable vats patch has not been applied. I don't know if this OS 12633056 needs it.
Everything seems in order, all voltages are good, all grounds are are good (body to frame, engine to frame, engine to body).
I don't even know what question to ask. I would like to get this engine running.
I need all vats parameters and explain G1208,1211 and any ides as to where/what else to do.
I added my tune file in case,Thanks
Attachment 23431
