Can't wait for this one. I have one ISF 2.8, and an ISX15 waiting for the EfiLive goodness.
Not sure what your ISF is in but for example on something like the Chinese Foton trucks with the 2.8L you would need to get some sort of adaptor because the J1939 comms port is not on the OBD-II connector, it is in the engine bay on a small 3 pin plug.
GMPX, you are correct. It's a Foton crew cab ute. Thanks for the info about the plug. Looks like I have a bit of pre-tune homework to do.
-Craig
What will the price be for the HD V2 interace and will the price of credits stay the same for the HD side?
Pricing has not been finalised. We've purposely held off until the first production run including all of the incidentals (cables, boxes etc...) are manufactured to ensure there are no price vs quality issues.
I expect we are 3-4 weeks from that point.
Cheers
Cindy
Any updates?
When a Cummins ECM is flashed with Calterm there are no vehicle specific parameters included in that flash assuming the cal was downloaded from qsol and created from scratch as it should be. If an ecm must be flashed with Calterm for whatever reason, you would save an image with Insite first then send the template back to the ecm afterwards. Otherwise you are stuck going through Insite one parameter at a time correcting all the data. If the import option becomes available people will have to understand that they must use the same cal that the engine was built with or at a minimum be within the same CPL and options as the engine they are working with. This is going to be difficult for someone that don't have access to qsol. However, all that being said there are a lot of us that would love to see an incal import option.
Sorry I missed your post smokinpete379, you are correct in that allowing the Incal file import option is going to trip a lot of people up because of the way the Cummins ECM's are flashed. For those that don't know when a flash is done the ECM itself erases all vehicle specific data which is a major pain and cannot be avoided. We have warnings in the software that come up and say this:
When EFILive programs this ECM all data from the file is flashed in to the target controller.
This data includes all TRIM values, VIN etc.
Please ensure the file you are about to flash is from the correct vehicle, it is always best to read the ECM first and use that file for editing.
Ideally people need to retrain themselves and always insist on reading every ECM they plan on programming (assuming it is to stay on the same vehicle).
I don't know the process in Insite to transfer all the vehicle specific trim data to a different ECM but it sounds like a pain and it not something we planned on implementing because the solution is to not use a generic tune supplied on those DVD's.
if you already have a v2 is this gunna be a update like the regular cummins was or do I have to buy the whole thing?
