Kris,
Install the latest V7/V8 software, you will find that there are some new tables.
Kris,
Take a look at my previous post #11 in this thread. That shows the tables to look at along with a basic walkthrough of the changes I did to mine. Same priciples will apply but may be slightly different numbers for your application. I had to use HP at the time so those are the tables I used in HP. Good luck!
I haven't plugged efilive into as I don't know if I should spend another $100 on license when it's already hooked up to hpt. Don't get me wrong I love EFIlive and I have no reason to switch.
I'm also upset that this jackass threw a 3200 stall in a stock convertible camaro that is being used for nothing more than putting around in.
Ya I saw that and it was helpful I'll try it out. Are those the only numbers you messed with?
Are you using efilive now to do it?
I did not try the new tables in EFIlive yet myself since I haven't had another unit to tune as of yet. If he has HP, then those 4 tables should fix his issue. You'd have to burn a license if you use efi to take care of it so if he's on HP now then use those 4 tables. (NOT plugging HP guys, I'd rather tune with EFI by far!) I will be trying EFI's table next round for sure...
Thank you very much. You've been a better help than I found over there. Which is another reason to stick with efilive. You guys here have always been helpful and for that I appreciate it.
And always Joe, thank you for helping if I get another chance to mess with a a6 I'll check it out. It's just something I got thrown into because I tune some ls cars.
Kris
Hi, I am new to the forum and have a torque converter noise when going into lockup it sounds like it is slipping bad (growl) the converter is a TCI 3000 stall 389 gears in rear 430hp and 400ftlbs at tires any help would be great!!!!!
Are you sure the TC bolts have not loosened...?
If the TCC is slipping you can try setting the minimum TCC pressure high (I'm not sure if your TCM has this table)...
but in anycase, TCC slippage is a physical problem.
On the camaro we were doing, played with all those settings listed(not that it matters in this case being as it HPT). But we had some funny sounds even though it felt great. Had the clutch lock up a little higher on the mph and it went away. It may not have even been the converter making the noise it could have been drone from the headers/exhaust on the car. I think it probably was the converter though. It was very minor but probably not ok for a brand new car to have that issue. Car seemed great after that...
I've noticed on the 2011 Camaro's that we have no TCC pressure table's. Would love to see that added to hold the converters. Deleting the slip table's helps but not enough.
