the wires were pulled out of the connector leading into the tranny on my 93 2500 gmc sierra. the truck wiring harness side !
is there a color code diagram for the truck side ? with pin numbers ? so i can rebuild the 11pin conector
PT shift table relationships:
basic relationships:
1->2 curve should be above 2->1 curve;
2->3 curve should be above 3->2 curve;
3->4 curve should be above 4->3 curve;
additional relationships:
3->2 curve should be above 1->2 curve;
4->3 curve should be above 2->3 curve;
this can be summarized as: the curves cannot cross anywhere;
if they cross anywhere, then you will not be able to predict what gear the PCM selects when the operating point hits the cross.
A few broken links here. I just found this and printed it into a spiral book. Great reference
http://www.grail-ss.com/GRAIL%20Webs...ETechGuide.pdf
so the tcc is commanded at light cruise in 4. and at wot in 2. and 3. gears?
any idea if the above links are now perhaps accessible somewhere else?
The link from post #33 above is broken, the destination file of that link does not exist anymore (error 404 file/directory not found).
