hey guys awesome forum here big ups i have a 08 omega v6 with 2014 ls3 hsv running gear am getting auto brake fault am wondering how i can disable this feature as i dont jave the system installed in my car
also if i can disable esm thanx
i also have a efilive flashscsn v2
Auto Brake as in 'AEB' ? Because the Flashscan only communicates with the ECM and TCM there is nothing you can do with EFILive to disable AEB.
ok thanx mate do u know which module it is that will need reprogramming to disable? thank you
Sent from my SM-G955F using Tapatalk
No I don't sorry
did you get this problem solved? i had the same and chased it for ages replacing many parts to find out it was the clock spring.
hey mate no i havnt can you explain your problem that tou had more as still needing to fix it
