E38 12607218 OS T42 Auto
Is it able to be disabled in EFI-Live?
If so where do I look other than B2523?
Thanks guys..
Thanks guys..
Not sure what vehicle you have but turning off the TCS will also disable the BTM system anyway.
It's an Autocross car with VZ Commodore Electricals and electronics, TRAC is off but it's still doing the BTM thing.. thanks for the reply.
Ah ok, it is probably defaulting to staying on. I think (someone might dispute this) if you are using a Ute tune then this is what happens, on the sedan tune it is ok.
99% sure it's a Sedan tune, I'll check..
Just find a sedan version with the same OS, turn off what you need for the conversion and I think you'll be fine.
Thanks for the help!
Just in case anyone here is interested this is the car>>
https://scontent-lax3-1.xx.fbcdn.net...f2&oe=56C11BBC
