I know it is in here somewhere, lol.
Could someone point me in the direction of a tutorial on setting up and tunning for speed density on a 411 running a 5.7 Vortec type system
Look at the Calc.VET tutorial, you can simply disable the MAF if you desire (honestly keep the MAF if you can in most cases). Calc.MAFT may be a better solution however as it deals with correcting the VE and calculating the MAF (wouldn't be needed if you go SD).
+1 on what Erik said.
