LC-1 free air calibration from FlashScan V2
First, do heater cal (if you haven't already):
- remove sensor from LC-1 module and power up for a few seconds, then power off;
- insert sensor into LC-1 module and power up again.
If you ever replace the sensor, you have to do this again.
Update V2 firmware/bootblock:
Make sure you have updated the V2 bootblock to latest and firmware to latest..
Configure V2:
On the V2 LCD/keypad go F4 Options->F1 Setup->F1 Edit Settings and set the following:
Ser PIDs -> YES
COM Port -> Wideband
WO2 Type -> Innovate
WO2 Format -> Both
WO2 Data -> AFR & EQ
Do free air cal (repeat occassionally):
- make sure sensor is in free air (engine has been off overnight, or expose sensor to air);
- on V2 menu, go F2 Scan Tool->F1 Data Logging->F3 Display WO2 and select the controller;
- press the power button (circle with vertical bar, overlays the zero key),
- it asks "Do free air calibration?", you answer Yes.
