2 Attachment(s)
Known issues with the October 2015 Public Pre-Release
Currently known issues and possible workarounds for the October 2015 Public Pre-Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions:
- Software: V7.5.7.296
- Software: V8.2.2.287
- FlashScan/AutoCal firmware: V2.07.92
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
In the V8 Scan Tool, opening or switching to a different dashboard that contains one or more PIDs that are not supported for the currently selected controller type will trigger an "Access Violation".
Workaround:
Manually select the correct controller type for the dashboard before opening or switching the dashboard.
Please see post #2 below regarding "Dashboard" vs "Scan Display".
Issue 3:
The EXT.AD1 and EXT.AD2 PIDs are named incorrectly in the sae_generic.txt file.
The Serial wide band BEN factor PIDs are missing from the sae_generic.txt file.
Workaround:
Download and save the corrected sae_generic.txt file into the folder: \Program Files (x86)\EFILive\V7.5\Configuration - overwrite the existing file.
Issue 4:
V7.5 dashboard names are not being saved correctly into log files during black box logging. That means the requested dashboard does not load automatically when opening those BBX log files.
Workaround:
None. Will be fixed in the next update.
Issue 5:
Full flashing is not yet supported for E86B controllers with boot block 12664192.
Workaround:
Download the attached E86B_12664192.zip file and unzip it into the folder: \Program Files (x86)\EFILive\V8, overwrite existing files.
If you are using Black Box Flashing, then after unzipping the attached file you must perform a [Check Firmware] option from the main V8 screen to update the files to your FlashScan device. If the files were unzipped successfully to your PC then E86B_F.obj file should display as "Update Required".
Issue 6:
Calculated AFR PIDs that should refer to EXT.AD2, instead refer to AD1.
Workaround:
Issue 7:
Calculated PIDs that are defined in the V8 scan tool using a prefix (i.e. source name) other than "CALC" (e.g. WO2A.AFR_LC11) are not automatically loaded/displayed when opening log files that contain those PIDs.
Workaround:
After opening the log file, re-select the desired calculated PIDs.
