Looking for info on why vehicle says it isn't licensed? Flashed several times on the dyno and now gives me the error that i need to license the controller.
thanks,
Brandon
thanks,
Brandon
Are you attempting to flash using V7 or V8 or V2 (in BBc mode)...?
Which PCM/ECM...?
I've tried both v7 and v8
Sent from my SM-G930V using Tapatalk
P59 PCM
Hi Brandon,
Could you please send the following files to me at paul@efilive.com
A *.lbu license backup file from your FlashScan.
A *.ctz file read from the controller after it started rejecting the VIN license.
A *.htx trace file of an attempt to flash the controller after it started rejecting the VIN license.
More info on how to generate/find the *.lbu and *.htx files:
https://support.efilive.com/kb_artic...8552-EOAJ-5912
https://support.efilive.com/kb_artic...9413-RPHL-6309
Paul Blackmore
