2 Attachment(s)
E92 Scan Issue
Good afternoon all. I have a strange issue that probably has a relatively easy fix. I have a Gen V E92 controller attached to a 4.3 V6 in my Camaro. I'm trying to get the Maps setup properly, but it keeps telling me that GM.EQIVRATIO is not a valid PID. Therefore it won't allow me to setup my error maps for AFR/EQ/LAMBDA etc. Attached is a screenshot of the PIDS page in Scan, and the calc_pids file. Any help would be appreciated, thank you.
GM.EQIVRATIO is for GenIII LS1 (i.e. LS1A, LS1B, E40).
For E92 use SAE.LAMBDA.
Replace instances of multiplication by GM.EQIVRATIO with division by SAE.LAMBDA.
Thanks Joe, I was going through some of your other posts and that was the conclusion I came to. I changed the calc_pids to reflect that. Thanks again.
