What are they? What're the criteria for determining which column the PCM uses? Is it related to http://forum.efilive.com/showthread....rformance+mode this post, as in can you wire up a "track" switch?
Normal - Consider this the default shift pattern, ALL vehicles would normally use this.
Performance - Some vehicles have a 'performance' , 'sport' , 'Tow/Haul' mode, it basically just gives you an alernate shift pattern for better performance but probably get worse MPG.
Hot - If the trans has overheated this shift pattern will be used (not selected by the driver).
Cruise - Used when the cruise control is active.
