D0754 would be one that looks related to D0782. But nevermind, I just now saw that the 140 is mm3 and not fuel pressure. I think the Axis Define charts mostly modify how far you can go with the tables later? Like in D0754 if you upped it from 140 mm3 to 160 mm3, you would be able to tune all the way up to 160 mm3 in D0782 instead of being limited to 140. Correct me if I'm wrong. I first discovered this in the Fuel Limiter section.
