A 2009 Escalade ECM & T43 TCM,
Along with a 2009 CR8 LS3 ECM & T43 TCM,
........plus a 2009 CR8 M6 ECM sent a couple of weeks ago.
Did you receive them okay?
Yeah I've gotten them :). My laptop took a dump so I've had to reload everything from scratch again. I'll try and get them uploaded in the next couple of days. Had to search for what the heck a CSV-R8 wal LOL.
Hi Tordne or anyone else, looking for a stock tune for an LS3 VXR8 (not sure the model name over in Aus) -
O/S 12624402
Cal: 12624488
Transmission: Manual 6 speed.
If anyone has a stock copy can they let me know? There is one tune on holdencrazy with the correct O/S but thats for a different market and also an auto.
Cheers in advance
Everything I've got is up on Holden Crazy already sorry. If you do come across one please sent it to me and I'll host it.
Will do, if I could find out the like for like model on the HSV front it would probably be easy. Everyone I know here has had their cars mapped and I've lost my original stock :'(
Hi Guys,
I sent Tordne a file for a 2009 CSV-R8 M6, OS12628990. I can personally confirm that this is a 100% stock, untouched LS3 M6 file. The 2009 CSV-R8 A6 files also came from me and they are also 100% untouched.
The CSV-R8 (Chevrolet Special Vehicle [sic] ) is the re-badged and not re-engineered version of the HSV Clubsport R8 and also the VXR.
I am 99.9% certain all Australian-built MY2009 LS3 M6's have the same tune file parameters -that includes the 2009 HSV Maloo M6 too; as there's a copy of one there on holdencrazy also, along with an 09 GTS. Though I can't vouch for the originality of those particular files.
With a bit of patience and time you could load the 2009 GTS (which is A6) and the Maloo M6 (same OS numbers) to see a list of the differences for the manual ECM and then do the same for yourself with the CSV-R8 A6 sharing the same OS you have. Enabling you to then make yourself a stock M6 file from the A6.
Or just copy and paste all the parameters over from the CSV-R8 M6 (One of the frustrations of EFI-L; not being able to load different OS's together!)
Or simply flash the file with the different OS into your car if needs be. :cheers:
Cheers! If you happend to have the m6 available that would be great as I couldnt see it on Tordne's site. There might be some differences due to regional changes as I noticed a lot more other than just the typical auto box when looking at my slightly own modified tune but it would be a good start!
Hi Stig,
Just scroll down the Holdencrazy stock files list and look right under the 09 Corvette ZR1 file, there are then three files listed for 2009 CSV-R8, you need the last one; OS12628990.
I double checked it last night with the original and it's as you need it, 100% stock.
I believe all the 2009 HSV VE cars had the same file (VXR-8, CSV-R8, Clubsport R8, GTS & the Maloo) though would stand to be corrected.
One person who is good to check with is "GMH308" on here. :cheers:
I am looking for a stock 2006 TBSS e40 pcm file. I found one on holden but the OS # doesn't match up and is off by one number. How or why would this be? Maybe a typo? I would like to start from scratch but know that the OS needs to be the same. Help is much appreciated.
Often the Os and calibration ID numbers are of by 1 so just maybe double check. It won't be a typo as it wouldn't find a match for the OS in the database ;)
