IAT resistor Pull timing for multiple Nitrous shots E38
Hi
i have a 2 stage plate system to go on my ls3 maloo and i also have a fogger which i am going to install
i was thinking of running first shot 50hp from around 2300rpm- 2500
then the 2nd 50hp at around 3000 - 3500 and bring the 3rd 50 in at 4000rpm
this will give me a softer hit, and the choice of how much gas i can use at any one time
i was thinking of wiring different ohm resistors up into the iat so it alters the reading down to say ,-10*c ,-20*c ,-30*c and pull timing that way individually for each shot.
i can also adjust injector flow based on iat to fine tune the mixtures
Can any one see any major reasons not to do it like this?
i dont want the custom os for the e38 as it will only let me pull timing at once for the 150 shot
thanks
