BD high idle connects to the pedal wiring and crank signal input. Here are the install instructions http://media.dieselops.com/media/ins...0&%20Dodge.pdf
From what I understand it just spoofs the APPS signal to get the engine to idle at X RPMs
It's been awhile since played with my 06. But did play with 6th tune and grounded pin for high idle. It will act like a 6th tune but still uses same base file like other csp5 files then do your adjustment . My original theory was to make a no load high idle instead of 1100 pto loaded. Hope this help.
Sent from my XT1585 using Tapatalk
