I wish EFI live had a lot of this built in to v8 would help but i'll play around with it and make sense of it eventually, just a learning curve thats all
Thanks really appreciate it. Ive read over your pids and understand it a little better but still need to read more into it. How do you apply the filters to the BEN map in V7 you apply the filter thru filters but not on here V8.
I want to apply a TP changing 5% to the map as im doing this at operating temps and wont fall below 185f.
Not sure what else i should apply. I want to try an get a very accuate and consistent map
Also boolean...is that a rate of change meaning?
boolean basically means true or false. Only two values can be returned.
The rate of change calculation is dx("PID",frame()-1,frame())
For the filters, you need to add them as part of the pid selection Attachment 23189
Then select the filter Attachment 23190
Then on "F4: Charts" you'll see a button to apply the selected filter to the right of the playback buttons. I believe this SHOULD apply to all charts, maps etc.
You may have to reselect the data pid at the top of your map, you should see the cells change based on the filters. It doesn't always auto update the map from what i can tell.
Ok im going to try it out thursday when i have free time to log. Ill let you know friday how it went. In the meantime going to keep reading and toying around with V8. The more i play around and experiment the more its making some more sense. Just a learning curve to overcome.
Check that the the MAP axis on the map has the same units as the MAP pid that was logged.
Hi Joecar, Thanks for the reply. I can confirm that the pid that is logged is ECM.MAP (kPa) and my map axis is ECM.MAP (kPa).
My progress so far can be found here: https://forum.efilive.com/showthread...4-Aem-ben-maps
Regards Jeff
