Does anyone have the latest firmware for V1, mine has gone haywire and needs to be reflashed.
Can't be done for a V1. If you have a V2 and you mis-typed the most current firmware is in the most recent EFILive program download.Quote:
Originally Posted by JET LEE
Are you having connection problems, like computer doesn't always see the cable?
Ira
well.....it worked fine for a couple of months, now when I try to connect the console gives "ERROR unregistered interface some features have been disabled". Now all I can do is scan : (
I haven't changed anything in the software. I double checked my SN, KEY, issue date and type to verify that they were correct.
Then, I uninstalled the software including drivers and reinstalled everything....still same error message.
When I go to Tuning-Help-Flashscan V1 PCM Licensing, I get the following:
Flashscan SN: I get the correct SN followed by two strange looking charcters then USB
Type: Unknown
Firmware version: 99.2.17
Model: FSP
Firmware date: 18-Jan-2005
Reflash counter: -2080374781 (Really strange the other day it said 3 which is correct)
PCM Licenses 1 available 1 used (correct)
Has to be a hardware problem. Andrew is looking into it, just posted to see if anyone else had this issue.
It basically won't be detected as a FlashScan interface as it seem the flash has some corruption.
