V1 to serial wideband connection?
I've got an innovate mtx-l plus wideband which had one programmable analog output and one serial output. Is there a way to connect the serial output to flashscan v1? Additionally, can the analog output provide accurate readings to the ecm to simulate narrowband o2?
My goal would be to connect the wideband sensor to both the flashscan v1 for logging and tuning as well as replace the existing narrowband while I tune.
If the analog output has to be used for both the narrowband and output to flashscan am I correct in thinking the output would have to be split and therefore cannot provide the correct signal at the same time to both the ecm and flashscan?
Thanks!
