Can not connect to Scan
So I have a new computer, installed latest version of V7.5 scan + Tune.
I can read the PCM vid Tune but I can not logg with Scan.
It is possible to connect to the PCM i Scan but when I start to read/Record I got a error.
Does anyone know what is wrong.
M
Error report generated by EFILive at 19:40:28 on okt 02, 2012
Error code: ERR_RESPONSE/5
Response $0F: .
EFILive Version: 7.5.7 (Build 211)
Platform: Windows NT
Version: 6.1 (build 7601)
Processor type: Pentium 2194MHz[/I][/I]
Hi RAIV,
Did you flash bootblock 2.07.04 and firmware 2.07.35 into your FlashScan V2 (requires installing V8 build 203)...?
After flashing that bootblock/firmware, did you configure BBx on V2 (include some files that are used for BBx and passthru modes)...?
More info: Setting-up-a-FSV2-from-scratch
Hi Joecar,
I had flash the right BB and FW but not the config. I have done that now, will check tomorrow if it works. Thanks for your support.
M
