2 Attachment(s)
E38 OS12658778 Keep pulling timing
I had this car that keep pulling timing no matter what , it won't go over 13 degree @ wot , I never seen such a thing .
It happens when I turn off the whole tq management or change any parameter regarding the timing .
With the stock tune it goes 18-22 degree @wot easily .
I have attached stock and tuned file .
Attachment 21781
Attachment 21782
Quote:
Originally Posted by
Eng.LSX
Yes
I had the exact problem on a 2016 SS sedan today. Timing was a bit higher at 16, but it would not go up no matter what I did.
I think there is an undefined table (max timing maybe?) or torque management pulling timing. Even happened with the stock tune. Should have logged the TM PIDs.
Eng.LSX
I think the file gets corrupted with changed parameters but it's definitely the tq management that is pulling , I will get the last update and try again .
When I flashed the stock tune in, the timing was nearly the same. I should have logged the TM PIDs. Did you log any of them by chance?
