Ecm pin grounding is required on all manual transmission trucks for any form of cruise control activated high idle. Auto trucks do not require that, just the option enabled.
Then we already have the parameter, I just looked on CMB CSP OS 55352409
F1041 - "Used to Enable/Disable the PTO (Power Take Off) option. If using the plug C2, pin 38 discrete input to switch tunes then this must be set to disable."
All the tunes I checked it seems to already be set to Enabled.
Does anyone have a definitely NOT enabled tune and definitely enabled tune they could please post up?
I looked through a tune that was supposed to have F1041 (C.C. High Idle) and I couldnt find F1041. Will I be able to see it?
It seems we only added it in to CSP5 OS's
Got it! Thanks! :notacrook:
