I know ive read a couple of threads about the 600rpm slip limit issues being solved but im still having issues getting my truck to lockup in 2nd gear at WOT. I have adjusted the TCC ramp rate to 800 in the 600 torque column and from 0 to 600rpm of slip. I also have questions as when to set the TCC lockup speeds ive tried setting mine at 33kph in second gear is that close to being correct? This is a 06 cummins truck with a 5 Speed allison ruining the Dstroked adapter kit behind it.
