Originally Posted by
ScarabEpic22
Since you cant communicate with the ECM via other scan tools or the AutoCal, have to solve that problem first. Wiring, fuses, etc. If that doesnt work, may need a new ECM (unlikely, but it happens occasionally).
For the AutoCal, EFILive provides the hardware only to tuning shops, they do not create nor sell tunes. I'd suggest contacting the tuner if you have issues after the ECM communication issues are resolved.
Here are what the error codes mean, they're not DTCs, they are AutoCal codes as the AutoCal cannot connect to the vehicle:
0280- No Vehicle detected (i.e. cannot connect to ECM)
0549- Ignition switched off (i.e. cannot connect to ECM)
0502- Script file not found (i.e. cannot connect to ECM to determine if the AutoCal is properly configured for this vehicle)
