Originally Posted by scan n tune
Error report generated by EFILive at 15:04:49 on May 12, 2009
Error code: ERR_RESPONSE/5
Response $11: "Mode Not Supported".
EFILive Version: 7.5.5 (Build 84)
Platform: Windows XP
Version: 5.1 (build 2600)
Processor type: Pentium 1995MHz
Directories
Temporary Cache: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Temporary cache
Logged Data: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Logged data
Customers: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Customers
Configuration: C:\Program Files\EFILive\V7.5\Configuration
Exported Data: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Exported data
Images: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Images
Sounds: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Sounds
Maps: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Maps
Pids: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\PIDs
Virtual Dash: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\VDash
Print Reports: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Print reports
Bug Reports: C:\Documents and Settings\Jason\My Documents\EFILive\V7.5\Bug reports
Connected: No
Com port: 0
Com setup: EFILive FlashScan V2.5: USB
Requested baud rate: 115200
Cable id: 7
Cable code: FlashScan V2
Cable desc: EFILive FlashScan V2
Cable version: 2.6.6
Cable Firmware date: 20081214
Cable model: FSV2
Cable Serial number: 003635578445
Protocols: 0
Protocol list:
Auto connect: No
Scan OBDII info: No
Error retries: 1
Retry delay: 10
Message throttle: 0
Most recently used VIN: 1GTJK33D07Fxxxxxx (Note: 1)
PCM information
Hardware Number: Unknown
Calibration ID: 12606127
Serial Number: 86J628603950
Operating System: 12632483
Engine Operation: 12632640
Engine Diagnostics: 12632655
Engine: 12632720
Not used: 12632666
Fuel System: 12632666
System: 12632677
Speedometer: 12632700
Boot Block: YNAY
Stream-Slow scan mode: Supported
Stream-Fast scan mode: Supported
Maximum dynamic packets: 16
Detected modules:
$11="Engine Control Module (ECM)"
$18="Transmission Control Module (TCM)"
Selected parameters:
CALC.POWER_RW=1,4308
GM.BOOST2_DMA=1,4440
GM.DESTCBOST=1,4478
GM.EGR=1,4503
GM.EGRCOM=1,4504
GM.ENGOILP=1,4517
GM.ENGTRQREF_DMA=1,4519
GM.FRPCOM=1,4599
GM.FRPDES=1,4601
GM.FUELRCALC=1,4614
GM.MAIN1Q_DMA=1,4736
GM.MAIN1T_DMA=1,4737
GM.MNINJTIM=1,4782
GM.PILOT1Q_DMA=1,4851
GM.TCVDES=1,4999
GM.TCVLRNC=1,5000
GM.TCVLRNO=1,5001
GM.TCVPOS=1,5002
GM.TP=1,5027
SAE.AAT=1,5091
SAE.BARO=1,5098
SAE.ECT=1,5113
SAE.EGR_PCT=1,5115
SAE.FRP_C=1,5123
SAE.IAT=1,5126
SAE.LOAD_PCT=1,5128
SAE.RPM=1,5152
SAE.TAC_PCT=1,5158
SAE.TP=1,5159
SAE.VPWR=1,5167
SAE.VSS=1,5168
