Hmm. That sounds right.. I just got excited and left it like that but when I get a chance I will see what it's actually doing
I dont have a truck to try it, but maybe make sure all of the desired boost tables are equal to or lower than the actual atmospheric pressure....
For example, B0727, says that in the idle RPM range, the maximum boost that can be commanded is almost 10psi over standard atmospheric pressure.....what does the ECM do when it wants the actual boost to meet the desired boost? It closes or opens the vanes....
You guys are right. I'm not making commanded boost. Hmm. I'll have to keep hunting to see how I can quiet down at idle.
I'll keep playing with it when I get a chance. Appreciate all the help.
Gotcha. Who doesn't like a good challenge? :grd:
Did anyone Ever get this issue Ironed out?
