not sure why i cant edit the stock file in v8 because the csp5 is supported by it.
is there something i have to do in order to make it work with v8?
controller description: cmc cm2100
os: 11551031
did i miss something on this stock file?
os: 11551031
Sounds like you are running software before CM2100 was migrated from V7 to V8. Please download and install the June 2021 public release software here https://www.efilive.com/download-efilive
I literally just downloaded the most current software. Is there any way you can double check the .ctz to make sure it will work on v8???
Every known OS was added in for this ECM for the most recent update (41 different factory OS's in total), yours was certainly one of them. I'll have the person that does the software builds confirm they all made it in (they are certainly all on my PC here).
Please create a ticket and send it via our help desk. https://service.efilive.com/new-ticket
Done! hope we can come to solve this situation!
The CMC *cam files were released after the June 2021 public release was made available. You will need to download and install this addition to be able to edit in V8.https://forum.efilive.com/showthread.php?30225-June-2021-Dodge-CMC-testing-in-V8
