LM-1 here.
LM-1 here.
FJO dual. But, only single hooked up - waiting on new motor install for dual use.
LM1 with the serial connection, goodbye ground plane issues!
Al
single LC-1 ...
Lm1 Ftw :D
PLX w/ RS232 converter
LM1, soon to be LC1 so I can get rid of the box.
LC-1 , hope to get the JAW I built to work as well .
Nice to be able to just plug in a wire and get digital AFR readings .
Hey guys, all these link up w/EFI Live's datalogger right?
Hi TFZ,
Yes, they do...
But the EFILive logging software (the scantool) allows you to create a calculated pid for any wideband that you use... you simply have to know what the wideband's analog voltage:afr transfer function looks like... and the software can handle linear and non-linear transfer functions!
If you have a FlashScan V2, pretty soon you will be able to log wideband AFR in serial digital form (i.e. RS-232), so you won't have to worry about analog voltage:afr transfer functions.
Joe
:cheers:
