Linking Scan Tool To Editor
In Version 7.5, I used a file E92_link.ini to link parameters between Scan Tool and the Editor. Is there a similar file to do this with the V8 Editor ? The reason I ask is that I changed the column information for the VE table to a calculated PID for Map/Barometer.
Thanks,
Walter
I read in the V8 Manual to right click in the Table (B8101, B8103 & B8105) and then Edit Column, Edit Row, etc. are changeable. When I do that the Edit Column is greyed out. The Column needs to be changed for those Tables from ECM.AFRATIO_M to a Calculated PID VVE.MAP_BARO.
