Yea I don't know. I probably won't even try to start it if it does work, because I imagine the security will go nuts.
I'll give it a go and report back.
Update: I can Licence the computer but when I flash it it is failing right at the end of the flash. Error $0340 Download not accepted. Trying to flash a stock file.
Attachment 21621
Yeah, unless the digital signatures have been disabled (using a BullyDog, Fleece etc) you will only be able to flash stock files.
As the $0340 error code description says:
For Cummins controllers: Controller contains security to prevent modified tunes being programmed.
Yes I know I am trying to flash an older Stock file so the BD can talk to it.
Do you have any 2018 stock files that I an try so if this doesn't work I can at least go back to stock. I have 10-17 files only
Do you know what was in it originally? 32370831AD etc
Yes I do have 2018 files.
I've tried 15' 16' and 17' files all with no luck, they get right to the end and fail, as if you were flashing a modified file, but these are all bone stock. I am on the latest software and firmware.
Close enough to get you going again....
