I know you can log wideband, and egt as outside inputs, but how many outside inputs can be connected to the Flashscan module? If you could abb boost, and fuel pressure, it would be perfect for a boosted app. :P
The Flashscan adaptor has one dedicated EGT (or TypeK thermocouple) input and two A/D 0-5V inputs. So if you have a boost sensor or F.P sensor that outputs within that range you could log it.
Are the FP sensor from digital gauges in that range that you know of?
I don't think they output voltage, but resistance...
anyway to adapt this?
Thx
What about the factory MAP sensor? Could that be used to indicate boost?
