I am having a problem not being able to link my tune tool to scan tool to track cells after logging. I have used this before when I had my 03 LB7, but have not been able to get it straight on my LMM. Any suggestions?
Which tables aren't following?
None of the tables would follow, I loaded a new CAL_LINK file from a member on dieselplace.com and it links together right, except now SAE.TP (throttle position) constantly reads 14.1% regardless of actual position :help2:
Does throttle position log correctly? If so make sure that the PID that is being refference in the tune is the same as the one in your log. If it isn't you will need to go into the cal_link file and manually change it to the correct one.
Yeah, I switched out SAE.TP for GM.APP in the CAL_LINK and everything is good
