1 Attachment(s)
E40 stock throttle body to 102mm, what table to adjust
I have a 06 gto with a 402 stroker, cammed, fast intake, nw102 throttlebody. ect....
The car idle fine and drives fine, I have adjusted the VE and MAF, and Idle air flow table b1829, but the car is hard to start, you have to step on the pedal slightly to get it to fire off.
Checking into the b1650, b1651, b1652, b1701
Tried to the math for area of the stock throttle and it doest come close to 4725mmsq, even with taking into account for the throttle blade.
I also noticed when i did a WOT pull the absolute throttle position was at 88.2%, dont knw whats up with that
Idk which way to go, any help would be much appreciated
Thanks Russ
