Originally Posted by
joecar
Updated instructions for installing updated software/firmware:
Download and install V7/V8...
then using V8 EFLive Explorer do this:
- goto thew Firmware tab,
- update the bootblock to 2.07.03,
- update the firmware to 2.07.21,
- exit from EE.
then using V8 Scan & Tune do this:
- goto the BBx tab,
- goto the Scan subtab,
- click Read,
- click Save (and if asked specify filename Options.txt),
- click the down arrow on the Program button and select Format Config File System,
- click the down arrow on the Program button and select Program All Required Data (Slower),
- exit from the subtab and exit from S&T.
Also, using V8 Scan & Tune, do the same on the Devices subtab (filename is Settings.dat).
