Can you please send trace files as per the end of this page: http://support.efilive.com/kb_articl...8254-QOGC-9586
Thank you Paul for all your work on the update! I installed all of it as soon as it came out and have already used it. V8 works great, but I did get a bootloader error in V7 trying to read an LS1b. I ended up reading it with V8, making changes in V7, then flashing with V8 just to be safe since the read failed.
I am having he same issue, I cant flash my LLY, I have to use the V8 software to download, I get a bootloader error. This never happened till I updated to build 211. Is this something you will be fixing in the next build release?
Can you please see the section titled "Further Support" on this page:
Send the trace files of the failed LS1B read, to me at paul@efilive.com, thanks
For anyone experiencing read/flash issues.
Please make sure you have the latest V8 software installed - which includes the latest firmware for your FlashScan device.
Once you have that software installed, click on the [Check Firmware] button to check (and update) the firmware on your FlashScan device.
You must have software: V8.2.1 build 203 as shown in the image below.
You must have firmware: V2.07.35 as shown in the image below.
Attachment 13419
Thanks, i put the latest version on and it works now!!!
I still have build 170 on the V8 and 180 on the 7.5. Is there anything special I should do to update?
See post #4 here (read the pdf very carefully and only proceed when understood): Can-I-view-misfire-counts
