URGENT HELP, CANT READ E38,E67,T43, ERROR $0101: No data received
Some days ago i tried to read a tune from a car im working on, i couldnt, it was a E38, today i tried to read an E67 and couldnt neither, tried to read a T43 and same results,, it does detect the ECM, read codes, delete codes, log, etc but i cant read the tune.. i did tried to read and tune a LS1B PCM and it did was possible, so i think there is a problem on the software side or the canbus hardware i dont know, but i really need to fix this, how can i diagnose this? have a couple of cars here i really need to tune, any help will be apreciated.
T43 0101 error "no data received"
Hi
I have the same problem... I have tried to read T43 with 8.2 and it says 0101 error "no data received"
With 7.5 I can get it read but after 15 sec countdown it cant be modified with 7.5, it says maybe with 8.2 but all calibrations and everything on left side are "unknown"
here is copied 7.5 text:
22.05.39.682: Scanning for EFILive FlashScan V2 HAPI
22.05.39.703: Autodetect interface ...
22.05.39.846: Interface firmware version: 2.7.113
22.05.39.856: Connection to [FSV2] interface is OK
22.05.39.871: CAN-VPW Bridge Activated
22.05.39.936: Current protocol set to: "ISO 15765 CAN"
22.05.39.945: Autodetect TCM...
22.05.39.978: Connection to TCM is OK
22.05.39.991: Current protocol: "ISO 15765 CAN"
22.05.40.107: USB driver version: 2.8.40
22.05.40.120: USB library version: 3.2.7
22.05.40.144: Interface firmware model: FSV2
22.05.40.165: Interface firmware version: 2.7.113
22.05.40.187: Interface firmware date: helmi 19, 2017
22.05.40.203: FlashScan serial number: 005001074033
22.05.40.215: FlashScan license number: 005001074033
22.05.40.228: FlashScan alternate license number: 005001074033
22.05.40.364: Getting status...
22.05.40.414: Status: OK.
22.05.43.783: Disconnecting ...
22.05.44.315: CAN-VPW Bridge Deactivated
22.05.44.335: Disconnected
22.05.44.999: Scanning for EFILive FlashScan V2 HAPI
22.05.45.029: Autodetect interface ...
22.05.45.186: Interface firmware version: 2.7.113
22.05.45.205: Connection to [FSV2] interface is OK
22.05.45.332: USB driver version: 2.8.40
22.05.45.353: USB library version: 3.2.7
22.05.45.379: Interface firmware model: FSV2
22.05.45.407: Interface firmware version: 2.7.113
22.05.45.434: Interface firmware date: helmi 19, 2017
22.05.45.463: FlashScan serial number: 005001074033
22.05.45.492: FlashScan license number: 005001074033
22.05.45.517: FlashScan alternate license number: 005001074033
22.05.45.565: Disconnecting ...
22.05.46.108: CAN-VPW Bridge Deactivated
22.05.46.128: Disconnected
22.05.46.796: Scanning for EFILive FlashScan V2 HAPI
22.05.46.828: Autodetect interface ...
22.05.46.970: Interface firmware version: 2.7.113
22.05.46.991: Connection to [FSV2] interface is OK
22.05.47.017: CAN-VPW Bridge Activated
22.05.47.098: Current protocol set to: "ISO 15765 CAN"
22.05.47.119: Autodetect TCM...
22.05.47.159: Connection to TCM is OK
22.05.47.185: Current protocol: "ISO 15765 CAN"
22.05.47.315: USB driver version: 2.8.40
22.05.47.338: USB library version: 3.2.7
22.05.47.365: Interface firmware model: FSV2
22.05.47.393: Interface firmware version: 2.7.113
22.05.47.420: Interface firmware date: helmi 19, 2017
22.05.47.449: FlashScan serial number: 005001074033
22.05.47.477: FlashScan license number: 005001074033
22.05.47.503: FlashScan alternate license number: 005001074033
22.05.47.658: Getting status...
22.05.47.701: Status: OK.
22.05.48.492: Bootloader version: T43a_v1.1R (0476-67C4)
22.05.48.507: Preparing TCM for reading flash...
22.05.48.539: TCM seed is: $5F91
22.05.48.556: Unlock attempt 1 of 1
22.05.48.683: Initializing TCM...
22.05.49.917: Initializing TCM, step 1 of 4
22.05.49.932: Initializing TCM, step 2 of 4
22.05.51.166: Initializing TCM, step 3 of 4
22.05.53.602: Initializing TCM, step 4 of 4
22.05.54.045: Initializing bootloader...
22.05.54.311: Initializing bootloader, step 1 of 3
22.05.54.640: Initializing bootloader, step 2 of 3
22.05.54.971: Initializing bootloader, step 3 of 3
22.05.55.989: TCM ready for reading flash.
22.05.56.112: ST M58BW016xB - 2MB
22.05.56.127: CPU Type: MPC561/MPC562
22.05.57.688: Total time: 00.00
22.05.57.701: Rebooting TCM... (please wait up to 8 seconds)
22.06.00.818: Waiting for TCM to complete reboot process... (Retry 1 of 8)
22.06.02.839: Waiting for TCM to complete reboot process... (Retry 2 of 8)
22.06.04.863: Waiting for TCM to complete reboot process... (Retry 3 of 8)
22.06.06.881: Waiting for TCM to complete reboot process... (Retry 4 of 8)
22.06.08.899: Waiting for TCM to complete reboot process... (Retry 5 of 8)
22.06.10.918: Waiting for TCM to complete reboot process... (Retry 6 of 8)
22.06.12.937: Waiting for TCM to complete reboot process... (Retry 7 of 8)
22.06.12.963: TCM has booted successfully...
22.06.13.982: Clear emisison related DTCs...
22.06.16.035: Autodetect interface ...
22.06.16.166: Interface firmware version: 2.7.113
22.06.16.183: Connection to [FSV2] interface is OK
22.06.16.202: Autodetect TCM...
22.06.16.232: Connection to TCM is OK
22.06.17.266: Clear DTCs for all modules...
22.06.19.311: Autodetect interface ...
22.06.19.441: Interface firmware version: 2.7.113
22.06.19.457: Connection to [FSV2] interface is OK
22.06.19.477: Autodetect TCM...
22.06.19.509: Connection to TCM is OK
22.06.22.246: Disconnecting ...
22.06.22.771: CAN-VPW Bridge Deactivated
22.06.22.786: Disconnected
22.06.24.556: Loading generic configuration file: sae_generic.txt
22.06.24.559: User defined calculated PIDs file: calc_pids.txt
22.06.24.562: Enhanced configuration file: gm_enhanced.prn
22.06.26.882: Done!
What could be wrong.. Now I have tested it with new usb cable and uninstalled those EFILive softwares and installed them again.. Still the same problem...
I'm new user and I have got it read that transmission T43 box 6.6.2017 and I have that original file... I have not made any changes after that..
-Riku
