Logging more than one data stream using Serial Data (Innovate Gauges)?
Question. I currently log AFR using the serial connection. The gauge I'm using is the Innovate SCG-1 which is a Boost Controller with wideband.
Can we also simultaneously log Boost/Solenoid duty-cycle along with the AFR? Haven't used LogWorks but the instructions say it's possible. Ofcourse we have the MAP too but just wondering.
Next question, the data ports in/out on these MTS gauges can be daisy chained and I just ordered a Fuel Pressure Gauge that can be connected to the SCG-1's input port. If the above is possible, can we also log Fuel Pressure using the Serial data port? Would def. be pretty awesome to have just one serial connection and be able to gather many streams of Data.
