Found out the reason for the PCM being locked. It turned out that the car has the EC38 series PCM in it. Will have to wait until the boys have the program available hopefully early in 2007.
Thanks. :cheers:
Thanks. :cheers:
I've got the same problem on an 06 6.0 liter Silverado - Seed $0B01
A little help here ?
What are you selecting for your pcm type? You need to select 99+ ls1 for it.
Why, it is an 06?
OK, that worked ?
The year of the vehicle is not as important as the PCM type controlling it all :)Quote:
Originally Posted by Extinct
just wanted to say having the picture to match up the pcm when you go to read.program.or scan was a kool idea some one needs a pat on the back for that
Thanks, glad someone appreciates it :)
