RTACS using EXT.WO2AFR1,GM.AFR and CALC.BEN1
I`m trying to alter the Main VE Table using EXT.WO2AFR1,GM.AFR and CALC.BEN1
I have read most of the articles regarding the theme in this section and in the Gen III, but I`m still unabe to set up up to make RTACS actually alter any values in the
VE Table.
RTACS IS working ok in my custom operating system (updating cells).
Preferably I want RTACS (with filtering) to update my Main VE Table using lambda values from B3605.
I have not yet succeded in getting GM.AFR to pick values from B3605, but I know how to make it pick from B3618 (verified on logging)
I have tried to edit the sae_generic and cal_link files according to the old articles on fixing STRIMS using RTACS.
Summary: I want the BEN1 factor between my GM.AFR and EXT.WO2AFR1 to correct the VE table until it`s as close as possible to 1.00
I do get RTACS is active, but it`s not updating any cells.
I will investigate more to make GM.AFR to pick values from B3605 (open loop), and use that table, if only I can make RTACS update at all
to obtain BEN1 to 1.00
Any inputs are highly appreciated :)
