Please download and install both the V7.5 and V8 software packages.
Both the V7.5 and V8 software was updated in this release, you must update both software packages.
Release Notes:
Known Issues:Check for known issues
here.
Please post new issues, questions or clarifications (large or small) in this thread.
As new issues are verified they will be posted in the "known issues" thread above.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 268
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 262
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.70 (Oct 03, 2014)
