2 Attachment(s)
Before I log data tomorrow...
I want to make sure I do this right, I live in Colorado which uses E10 fuel so I've changed B3601 to 14.12 and I want to change calc.pids.txt to reflect Joecar's formula if necessary: {EXT.AD1} * 1.921 + 9.605, but there's there's other information in the area to the left of where the expression goes, using another line for an example:
*CLC-00-030
factor 0 1 .0 "{GM.EQIVRATIO}>1 && {SAE.RPM}>1200".
I've attached calc.pids.txt and Calc-VET-0000.pid which has a line inserted for my LC-1.
This is an LS1 with a 411 PCM in an '82 Vette, I'm tuning because I put in a 383 short block and ported 202 heads and mild cam so I know VE and MAF are going to be off from the relatively stock '02 LS1 that preceded it. I'm using a V2 and an LC-1 to do this.Attachment 19437Attachment 19438
I think I'm ready other than this, can anyone help me out with this?
