Yeah they all have a defined axis. The table on the left is the axis table for the one on the right. But I want to be able to make a change to the axis( left table) and it show the changes on the right table. If that makes sense.
It does, but TBH I am not sure the .cax files have the ability to define that. I don't know I don't use them, I'll have to ask Paul.
I know I can change the axis outside of efi and efi will display what I desired on the outside within the software. I haven't tried it like this, but not a bad idea!
Yeah, I don't really have an Idea. I tried defining the Hex Address for each axis value, but that was a no go.
If I change a table axis of a table of a EFI Defined table outside of EFI, then load it, when loaded into EFI it will show the new values, and I was sorta wanting the AXIS of the tables I define with the CAX to do the same. But I don't really think its possible or I don't know how to. but if you cant, would be a cool idea to add. :tongue:
It would be cool if you could add the AXIS tables for tables that are already defined Kory, but it won't load them saying the .cax overlaps predefined data. So I think those have to be changed outside EFI unless ross can unlock them somehow?? But tables you add yourself, you can add those axis tables. :P I kinda wanna get it setup so I only have to do all the changes in one program instead of using several and swapping between them all. haha
Is there a way to load a cax without having to define a "Minor" folder location?
Example:
If you don't include the "Minor" part, it screws the whole cax up, but if you put a "." it will make the folder name as such.... I just wanted to add the parameters to the "Major" Folder....Code:; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 2 "Main Injection Mode Assignment" "Injection Control" "Additional Parameters" 1 2 0 0
Is this possible?
from memory use a double, double quote. like ""
What kangsta said, try an empty string (i.e. "")...
( I'm not sure that it will work... but let see what it does. )
Or try just the . without any quotes at all.
