Changing the vin number in efi live
Hello,
I had to get a new ecm and I have changed the vin in the very first text box under the first tab called calibration in efi live editor 7.5
The problem is that when I go to do a full flash the output still has the old vin number. How can I change this?
I changed it here (notice it starts with a 3)
http://i1056.photobucket.com/albums/...pssayfukfc.png
Then I flash......
Code:
Executing: C:\Program Files (x86)\EFILive\V8\Config\CMC_F.obj
Virtual Machine Started
Script Loaded
Script Verified
Checking Data File...
VIN: 1D7KS28A77J585018 /////////////////***** THIS IS WRONG *****
OS: 55551035
Serial: 000000007283
Unlocking: Trying MFG key...
Erasing: Wait...
Programming...
Erasing: Wait...
Programming...
Erasing: Wait...
Programming...
Erasing: Wait...
Programming...
Erasing: Wait...
Programming...
Script finished successfully.
I assume you change it here
http://i1056.photobucket.com/albums/...psrx3gtjbu.png
but what controller do you use for 6.7L cummins?
